Thank you all for your answers with my original Help! thread.
Ok I registered my domain. Signed up for hosting with total choice. Figured out(sorta) how to set up some e-mail accounts- I can send and receive. On a recommendation I purchased sitespinner, and must admit it seems easy. Now I have designed a under construction page, I publish it and enter in mysite info and go there and nothing. Is there something somewhere I have to turn on? Have I provided enough information? Thanks!
It would help to have a domain. The most common problem in not seeing your site is publishing to the wrong folder. You should put all files you want visible in the public_html folder.
This is the reprot I get. When I go to my site I can't find it.
Collecting Files In:
C:\PROGRA~1\VIRTUA~1\SITESP~1\mysite\
Collecting file: Daiseys.jpg (51978 bytes)
Collecting file: index.html (1823 bytes)
Collecting file: unnamed.ims (3280 bytes)
Establishing connection to server: www.teachmetotalk.com
Preparing to Connect ...
Connection Established!
Set Remote Path to '/public_html/images'
Connection made to server: www.teachmetotalk.com
Transferring file: /public_html/images/image/Daiseys.jpg (51978 bytes)
Transferring file: /public_html/images/index.html (1823 bytes)
Transferring file: /public_html/images/unnamed.ims (3280 bytes)
-----------------End----------------
Transfer completed without errors!
Tell me if I should edit and delete that please.
Since I know nothing of that program I don't know how to tell you to set it up for publishing but you are putting your content below the public_html folder into a folder called images.
The index.html file needs to be in the public_html folder.
alright so now if I click the images folder i get the image i want...how do I make it so that that's the image you get if you type in our address?
I don't have a public_html folder
Parent Directory 21-Jul-2005 16:26 -
_private/ 21-Jul-2005 11:17 -
cgi-bin/ 21-Jul-2005 11:17 -
images/ 21-Jul-2005 16:32 -
postinfo.html 21-Jul-2005 11:17 2k
You do have a public_html folder, these folders are in it. I see you have your construction page up so it looks like you are making progress.
