ronaldp423 0 Posted May 20, 2005 Share Posted May 20, 2005 Everything was working just beautifully, then, I clicked to switch from one template to another(both of which have been working fine) and all my post are gone. I have an error message instead. Anyone know what this is and how to fix it. WordPress database error: [Got error 28 from table handler] SELECT * FROM wp_posts WHERE 1=1 AND YEAR(post_date)=2005 AND MONTH(post_date)=05 AND (post_status = "publish" OR post_author = 1 AND post_status != 'draft' AND post_status != 'static') GROUP BY wp_posts.ID ORDER BY post_date DESC Thanks ronpemberton.com Quote Link to post Share on other sites
TCH-Don 0 Posted May 20, 2005 Share Posted May 20, 2005 Not a WP user, but did you try to switch back to the previous template? (I know you did, but just checking) Do you have a backup of your database? Quote Link to post Share on other sites
ronaldp423 0 Posted May 21, 2005 Author Share Posted May 21, 2005 Not a WP user,but did you try to switch back to the previous template? (I know you did, but just checking) Do you have a backup of your database? <{POST_SNAPBACK}> I have been doing full backups in cpanel, will this work ? i'm completely new at this. Quote Link to post Share on other sites
TCH-Rick 0 Posted May 21, 2005 Share Posted May 21, 2005 IM me if you have AIM or Yahoo and I will look at it in a bit. Quote Link to post Share on other sites
TCH-Rick 0 Posted May 21, 2005 Share Posted May 21, 2005 Everything should be fine now. Please test it and let me know if there is still a problem. Quote Link to post Share on other sites
ronaldp423 0 Posted May 21, 2005 Author Share Posted May 21, 2005 Everything should be fine now. Please test it and let me know if there is still a problem. <{POST_SNAPBACK}> Everything seems to be ok. Thank you. What exactly did you do, and is it something I did unknowingly to cause it? Quote Link to post Share on other sites
TCH-Rick 0 Posted May 21, 2005 Share Posted May 21, 2005 There was a problem with the /tmp folder on the server being full. Someone else IMed me with the same error on the same server so I took a look. Quote Link to post Share on other sites
ronaldp423 0 Posted May 21, 2005 Author Share Posted May 21, 2005 There was a problem with the /tmp folder on the server being full. Someone else IMed me with the same error on the same server so I took a look. <{POST_SNAPBACK}> Thank you for your incrediable response time on this. Sincerely, you guys are very impressive with your customer service and technical panache. Many kudos!!!! Quote Link to post Share on other sites
