claypage Posted May 14, 2005 Posted May 14, 2005 Hello All! I'm working on my 5th site that's hosted by TCH. For this one I'm attempting to install PlansCalendar. I've followed the directions to a T, but I'm still getting the 500 Error. The site I'm working on is www.capitaldistrictkeyclub.org/calendar/plans.cgi I wasn't sure if there was something on TCH's end that I needed to know about. Also, if you go to the calendar directory, all the files are displayed. How can I fix this? Thanks, Matt Brent Quote
TCH-Bruce Posted May 14, 2005 Posted May 14, 2005 Normally a 500 error indicates you uploaded the scripts in Binary mode when they should have been uploaded in ASCII mode. Quote
TCH-Rick Posted May 14, 2005 Posted May 14, 2005 The calendar folder had permissions set to 775. It should be set to 755 to use for perl scripts. I changed the permissions and it is working fine. Quote
