(I typed "ssh" into the TCH knowledge base search engine and it didn't
find anything.)
When I ssh into my server, I end up at the virtual ROOT directory, not
my $HOME directory:
$ ssh server20.totalchoicehosting.com pwd
This isn't true of any other machine into which I use ssh - they all
put me in my $HOME directory. Not being in $HOME breaks all my "rsync"
scripts and ssh commands for updating my site remotely.
While I can rewrite all my rsync and ssh scripts to work around this, I
would like to inquire if there is a simple way to have my ssh connection
put me in my $HOME directory and not in the virtual (jailshell) ROOT.
I suspect the act of doing the chroot in the jailshell loses the
initial $HOME setting from the sshd login and I end up at the root of
the chroot and not in my $HOME directory.
If this is the problem, the simple fix I would suggest is to pass an
appropriate BASH_ENV to the jailshell in the environment, pointing to a
TCH profile file (inside the chroot jail) that does a simple "cd" to set
the $HOME. (Reference: the "INVOCATION" section of the bash man page.)
Is this the right place to post this? Should I send in a help desk ticket?
In the jailshell chroot environment /tmp is not writable by me (owned
bv root, no perms), which breaks many of my scripts. (I've never worked
on a machine with an unwritable /tmp.)
I'm not too familiar with how the chroot environment is set up; but,
perhaps the chroot /tmp could be made a symlink to my $HOME/tmp (which
I can write); or, simply add the missing permissions to /tmp ?
Failing either of these things, I can rewrite the scripts to use $TMP
and point $TMP at my own $HOME/tmp ...
Oh dear. I set you up in my "gaim" client; but, when I call up an IM window
and type in a message to you, gaim segfaults and drops a core file...
Plan B? Perhaps one of the other plug-ins is more stable?
AIM - idallen2
ICQ - 8313669
MSN - idallen@hotmail.com
Just to close off this thread in case anyone else using ssh stumbles across it:
Bill got back to me immediately about the ssh chroot "jailshell"
environment and explained that it was something of a work-in-progress
and that I had discovered some of its problems.
After reviewing my credentials and then making me pass six exams, three
character references, two bribes and one prayer to a lesser god, Bill
gave me a real shell prompt instead of the jailshell and everything is
fine now. :-)
I don't blame him, and in fact I'm very grateful for his caution. This is shared hosting after all, and not a good place for anyone running loose with too much access and not enough knowledge. You certainly seem to have the requisite knowledge, but I am glad that Bill grilled you good to make quadruple sure.
That being said, congratulations on your "parole."
