With all the talks of backups, I've realized that I'm a guilty party in not doing them often enough. So I'm attempting to create a backup plan for my accounts (I'm a reseller).
So, I made a backup of the accounts and am downloading them now. But I notice the speed is pretty slow. about 13-14kbs. I'm on broadband and I usually see 2-5mbps download.
I thought maybe there might be a cap if an FTP process or the disk thrashing caused too much of a hit on the server. Or, maybe there's something wrong with my throuput on this end.
Anybody have any info on this?
Thanks!
As we have said time and time again, the forums are not an official means of support.
However, with that said I logged into your FTP account and was able to download a 5.14MB file from your account using my home 'adsl' connection. I was able to pull over 5mbps download. Tested 3 times, each time same result :)
I would think it would be a routing issue or connectivity issue with your ISP.
Here is the FTP sampling from the download session, just so there are 'no' questions.
I have sent you a PM bill with the complete FTP sampling, however I have removed your username, IP, and username on the forums to protect your identity.
Also, I have accented the download speeds in the FTP sampling.
Resolving host name *******...
Connecting to (*******) -> IP: ***** PORT: 21
Connected to (*******) -> Time = 46ms
Socket connected waiting for login sequence.
220---------- Welcome to Pure-FTPd [TLS] ----------
220-You are user number 4 of 50 allowed.
220-Local time is now 17:43. Server port: 21.
220-This is a private system - No anonymous login
220 You will be disconnected after 15 minutes of inactivity.
USER *****
331 User ****** OK. Password required
PASS (hidden)
230-User ****** has group access to: ******
230 OK. Current restricted directory is /
SYST
215 UNIX Type: L8
FEAT
211-Extensions supported:
EPRT
IDLE
MDTM
SIZE
REST STREAM
MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
MLSD
ESTP
PASV
EPSV
SPSV
ESTA
AUTH TLS
PBSZ
PROT
211 End.
Detected Server Software: PureFTPd
PWD
257 "/" is your current location
Cached directory reloaded.
CWD /.spamassassin
250 OK. Current directory is /.spamassassin
PWD
257 "/.spamassassin" is your current location
TYPE I
200 TYPE is now 8-bit binary
PASV
227 Entering Passive Mode (********)
Opening data connection IP: ********* PORT: 29121.
RETR auto-whitelist
150-Accepted data connection
150 5140.0 kbytes to download
5263360 bytes received successfully. (642.50 KB/s) (00:00:08).
226-File successfully transferred
226 8.267 seconds (measured here), 0.61 Mbytes per second
Hi Bill,
I didn't even think this was necessarily a problem, so I wasn't expecting an immediate response as it were. It's been a while since I've done any large FTP download.
In short, you definitely answered my question ... if there is any cap (which there doesn't seem to be) that it's well above the 14kbs or so that I'm still experiencing.
If there happened to be a cap on FTP transfers, I have no doubt it would be there for good reason ... to keep the servers stable and free from abuse.
So it appears that I am having an issue, and that issue is something related to me on my end. Software, ISP, OS ... who knows. But it is worth looking into since it is having quite an effect on me. I have a download that will take an entire hour when all is said and done.
Thanks for the detail on this. Forgive me if it was a silly question. But it really was a question, and not a gripe, problem, complaint or anything else of the sort.
I leave a little smarter now! :)
Thanks for passing on the knowledge!
Bill
