With some html coding?
Someone made me a very beautiful layout for one of my sites and I'd love to be able to use it. It's already all coded, I just need to change a few things.
The things I need help with are getting an index page so the index directory doesn't show up and I need help with the links. I've changed the URL in the links from theirs to mine and everytime I click on the links their URL is still showing the address bar.
Here's their URL:
http://mirror.sketchy-milk.net/betty.html
Here's mine:
http://www.with-great-power.net/Practice2/
And when you click on the links all you get is the html coding.
you have a file called "Index", change it to "index.html" or "index.php" (I prefer the latter, but hey) That should fix the first part, after which the second one can be address if it is still a problem =)
It's always the simplest things. Got one thing out of the way. Will work on the second problem some more tonight and I hope it's alright if I ask for more help if I need it.
