agusus Posted December 7, 2004 Posted December 7, 2004 I'm trying to write a CGI script that would telnet to an external host (a chess server), and retrieve a list of users to display on a webpage (updated every hour or so). But I can't connect to the host (using Perl's Net/Telnet.pm module). When I try to ping the host from the TCH server, I get: ping: icmp open socket: Operation not permitted does this mean you're blocking socket connections? Does anyone know another way I can do this? Quote
TCH-RobertM Posted December 7, 2004 Posted December 7, 2004 wouldn't that require shell access to run ? if so I dont believe that TCH allows that on shared servers. I just finished reading something about that a minute ago which is why I am replying if I am incorrect please excuse my ignorance Quote
jandafields Posted December 7, 2004 Posted December 7, 2004 No, it would not require shell access to run, just a regular cgi script. You can see that the user is actually running the commands without shell access, the problem is the error that it is returning. About the error: Actually, the ping error can be fixed by editing a config file (usually the vserver .conf file) Search CAP_NET_RAW for your own personal satisfaction and entertainment if you want. However, access to raw ICMP sockets is disabled for security reasons on many shared servers. I am sure that is the reason here. Anyway, what error are you getting when you actually try to connect (not the ping error). Quote
MikeJ Posted December 7, 2004 Posted December 7, 2004 We do block some outgoing non-standard connections. If there is a particular one you need, submit a support ticket with the information about what you need access to. Quote
