Don't know if this is the right forum for this, so if it needs to be moved, that's fine.
Ok, i've mostly used Dreamweaver to build my websites in HTML. I see more and more sites using PHP and, quite honestly, I'd like to learn about it and see if that would be a better way. Are there PHP editors similar to dreamweaver? Obviously, i'm a complete newb when it comes to this. Any sites and/or tools would be helpful. Thanks!
Marc
You can use DreamWeaver to create and edit Php. I recommend getting a PHP IDE so you can test your scripts and pages locally.
moving for organization
I do not use DW, but I bet most switch to php
for one reason at first.
And that is to use the include function to include code common to all pages,
such as a common menu that appears on all pages.
If the menu is on a template or page, it has to be updated on all pages when adding a new page, and then all pages uploaded.
But if you replace the menu in the template or pages
with the php code
<?php
include $_SERVER['DOCUMENT_ROOT']."/menu.php";
then to add a page is as easy as creating the page with the menu include,
modify the menu.php file
and just upload the two files rather than the whole site.
I would suggest a book on learning php, as it is easier to follow.
But there are sites that show this idea and more.
Don,
This is probably a dumb question because I am not at all familiar with php, but how is using php for an include different than just doing a regular include with html? In Dreamweaver, I use the comment function to attach a disclaimer from a separate file at the bottom of all of my pages. If the disclaimer changes, I simply change it and upload the one file.
As I mentioned I am not familiar with DW.
I am glad there is a way to include files like a menu or others.
Not all programs will do that.
For me, coding by hand, this was a nice bonus.
And not the only reason to look at php.
It is a very easy to learn scripting language
giving you the ability to create or modify thousands of scripts
or add logic to your site and its free :dance:
Its worth looking at, you never know when it will come in handy.
