Twelve,
You will need to create a database in you cPanel. After you create the database you will create a user and then assign that user to the database. Then you will have your information to fill in the forum config requirements.
In my cpanel it's under "Addon Scripts"; That may be different for different themes t hough, so look for that or something similar. =) Then it'll say phpbb along with a list of other scripts to install.
I went to Addon Scripts and this is what I have:
Addon Scripts
"The following addon scripts are available to be installed:
InvisionBoard
InvisionBoard is a web bulletin board system.
PHP-Nuke
PHP-Nuke is an advanced content management system.
osCommerce
osCommerce is an easy to use and configure shopping cart system.
phpBB
phpBB is a web bulletin board system.
AdvancedGuestBook
Advanced Guestbook is a PHP-based guestbook script."
However it is just plain text, I don't see how I can actually install them.
Oh, looks like it is a link after all. Ok so now it wants me to give it the admin user and pass, I am pretty sure I have those. But when it askes install at this url there is a blank after www.virtualalex.com/ _____ what do I put there? Forums?
phpBB 2.0.8a Setup
New Installation
Admin User: Admin Pass:
Install at this url: http://virtualalex.com/
(You must install in a top level directory. Example: 'http://virtualalex.com/phpBB' is a valid place to install, but 'http://virtualalex.com/user/andy/phpBB' is not.
Modify an existing Installation
Upgrade an existing Installation
Remove an existing Installation
Twelve,
When it asks for a user name and password don't use your cpanel user name and password. Enter a username you want to use to administer the forum and a password for that user.
You need to install the forum into a folder in your domain space. So if you want to install it into a folder called "forums" enter "forums" in the blank field.
OK it seems to be working. I have 2 questions though.
Firstly, avatars don't seem to be working. I have the options set to 120x120 49kb avators. I have tried uploading one from my machine and it deasn't work, and I tried putting in a URL that also did not work.
Secondly is there a way I can put a banner back to my main site on the forum index? I don't want people to be stranded once they click on the forum button.
Go to the folder you installed the forum. You should have an images folder. In that folder there should be a folder called avatars. That is the folder that needs 777 permissions.
Next there should be a templates folder at the same level as the images folder. In that folder are folders for what ever themes you have installed. In each of the theme folders is where the template files can be found.
Ok I think I may have messed something up... There is no forums folder in my site folder. Althought there is a forum folder on my desktop... I downloaded phpbb of the website, but it seems that tch installed it by themselves so I took the forums folder out of my site folder an the forum still works fine.
Botton line is, there is www.virtualalex.com/forums is where my forum is now, the folder on my desktop is and always has been titled "forum" not "forums" so I don't think it's being used.
How is this possible?
I would really like to thank all of you guys for being so helpful and being so quick about it. I can always count on an answer to my latest questions within a few hours. Thanks alot.
Dick- I downloaded the extension (I am using DW MX 2004 7.0) and I am not sure where to put it, or how to install it. Could you help me out with that? And then after it's installed how do I set premissions?
Twelve, sorry, I assumed you were a Windows user. Glad to know you're not part of The Legion ;) (just kidding :))
As for the DW extension, I don't know how it works on the Mac but the Windows version of Macromedia products has a little utility called Extension Manager, from which you can install, uninstall and mess around with all the extensions you have installed for their products. Also, if I recall correctly, you can double-click an extension file and it will automatically be installed.
Just click/double click the file SetPermissions3.mxp this will open your Extensions Manager and just accept. The extension will install, and notify you of a successful install. Select OK and then you will the see the following:
This extension for Dreamweaver MX 2004, version 7.0.1, allows users to set remote file permissions via FTP.
To use this extension, select the file(s) in the remote file list on which you wish to set permissions,
then choose the "Set Permissions..." menu item from the context menu.
Not all FTP servers support this functionality.
Access: From the Site context menu.
Edited by TCH-Dick
Alright thanks alot, it seems that everythins is working fine.
One last thing. In the forum configuration I set the clock to be GMT-5 but it wont work and it keeps showing the GMT time. No matter how I change it the time always remains the same. How do I get this fixed?
If you're using the cPanel version, it may be a bug due to that version being outdated. If so, you could try upgrading to the latest version and see if it fixes the problem.
In your admin > Forum Permissions Control > select a forum
change permissions of each forum to suite.
i.e. POST and REPLY set to REG (registered)
There is a lot of control in the admin panel
if you look around, you will be surprised :)
