this is driving me nuts!
I created a new page with a simple form in frontpage 2002, and then published it to my site.
When I open the page, it shows the following message at the top of the form,
"[FrontPage Save Results Component]"
the when I try to use the form and press "submit", I get a new page with
"Cannot run the FrontPage Server Extensions on this page: "*****/new_page_1.htm"
cPanel shows my frontpage extensions are installed, but I uninstalled and reinstalled anyway. I still have the problem.
HELP! Mad!!!
Many FP forms must be editted live on your site. Use the Open Web option on the File menu and then open the form and edit it. Then save it back to the site.
Rick, thanks for the quick advice.
I opened my website in fp and deleted the text in the html, but fp wouldn't let me save the changes (can't modify part of an fp component). don't know if that would have solved the problem anyway.
However, I uninstalled and then reinstalled fp extensions (even though I already did that last night), and now the form works.
I read somewhere on the net that it is possible to "break" your extensions by testing a form on your computer... don't know.
Important thing is now the form works... at least for now.
