Does anyone know if there's a way to set the increments by which IrfanView sharpens an image? In my Camedia software, which came with my Olympus camera, the sharpen feature works in very small increments. Irfan seems to take a hefty leap each time you apply Sharpen. It would be nice if you could back that down to a smaller increment which could be applied multiple times.
Anyone know? I'm using V 3.91. Thanks. :)
From the online help:
Enter a value (1-99) to control how deep the sharpen effect is; higher numbers sharpen the image more; the default is 30.
From the Image menu, select Effects and then Effects browser. You can select Sharpen from there and change the value.
I bow to you all - you are my heroes! I've only played with it for a few hours and have had a ball. What an amazing little program it is. It's making major improvements on my website, that's for sure.
Don - I found the bevel settings when I was playing with making buttons the other day, too cool!
Thanks all of you for your help! :)
I have 4 images that are dark, but that's because of my scanner. They are transparancies and the quality just isn't there in the scan, even though the HP scanner I have is equipped with a transparency function. I got semi-decent results playing with the gamma and contrast, but nothing to brag about.
I'm liking Irfan more and more as I play with it. I'm actually going to rescan all of the images I did for the page I created yesterday, LOL.
Thanks again for all of your help. :)
There's a series of Irfanview tutorials here if anyone is interested:
*ttp://www.indeavors.com/services_wbt_ivtutorial.htm
They are made with another handy program called WINK. (link to that program is on the start page of tutorials if you want it)
-Samantha
I've used many versions of Irfanview and it only gets better.
I really liked using Wink to create a few tutorials for CSB. Simple clean and easy program. And of course the price is right tooo. Looking forward to the next release.
-Samantha
