I'm installing the vwar php script which uses a mySQL db. I created the db, uploaded files, set permissions and ran the install.php. The result is an error. I looked up the error in the vwar faq and the problem (evidently) is that I used the wrong localhost. Permissions are correct.
What localhost should I use? I tried:
localhost
www.server47totalchoicehosting.com
Error is:
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/man1958/public_html/vwar/includes/classes/class_db.php on line 190
Warning: Cannot modify header information - headers already sent by (output started at /home/man1958/public_html/vwar/includes/classes/class_db.php:190) in /home/man1958/public_html/vwar/install/install.php on line 332
I will provide any info you request. Thanks for helping.
I used the user/pw/dbname found in the cpanel under mysql just after I created the db (triple checked). After creating the db, I did not use the "add user" and "add host" at the bottom of the screen. I assume those are for additions.
Using "localhost" as the "Database Server" results in the error message above. Using anything else results in "database not found." So maybe "localhost" is correct, but something else is wrong. Here is the install file:
http://mandolinwind.com/vwar/install/install.php
I will provide user/pw on PM if needed.
The VWAR FAQ regarding the error message found above:
http://web8.bmbnet.com/FAQ.html#2_3
Username should just be your CPanel login name. Password should be the same.
DB name should just be cpanelusername_dbname
Does that match up with the information you've put in?
amansker, that error does not mean you're using the wrong database host, it means there was an error while processing the SQL query.
Try adding or die("Error: ".mysql_error()) at the enq of the query line, like this:
$result = mysql_query($query) or die("Error: ".mysql_error());
That should outupt the problem.
I PM'd and was told to submit a work ticket which I did - before reading the last two posts.
Rob: Are you saying it is mandatory to manually create a user and then add it to the db? I see that function, but have been using the cpanel user/pw as suggested elsewhere.
Raul: I'm not sure how to do what you are suggesting. I'm running an install file:
and not certain where to add the code you suggest. I guess that goes in the install.php file? Will try now.
I SUBMITTED A HELP TICKET SO YOU GUYS MIGHT WANT TO IGNORE THIS.
Yeah amansker... After thinking about this, I think there's a coding problem in the script that you're using to install. But better to listen to what the techs say in the ticket, lol...
These are my stept to creating my db info.
Create database
Create user
Add user to database
If I create database "stuff" I get a db name of cPanel-name_stuff
I then create a user "admin" and the username to access the db is cPanel-name_admin
Then I add the name to the database
See image below.
