On staff.marve.se i have placed a weathersticker.
The problem is that it shows up when i view the page on my computer, but not on Jessicas comp. Both comps are configured same way regarding pop ups etc.
Can anyone have a look to see if it shows up for them/you.
It is a password protected area of marve.se so you will need the following info,
Username: TCH
Password: tchtrial
(Note: This info is temporarily set up for this test, it will be deleted later)
The site is in swedish so when logged in, in left column look for "Meny" then "Min sida" and then "Min sida" (the actual link) and the page will show up in the right frame.
Question: Do you see a weathersticker from wunderground.com or just a white little spot? If you only see the white spot, any ideas how to solve this is appreciated.
Thanks in advance.
It works fine for me (brrr it's cold there:)) in Outlook 6, Opera 7 and Firefox 0.8.
Does Jessica have any ad-blockers on her machine?
Yup, she has. I just forgot to mention that those are disabled too in my "Both comps are configured same way regarding pop ups etc."
So to summarize, no pop up blockers or ad blockers are being enabled when looking at that. :D
Case closed.
I not only disabled everything named pop ups and ad blockers, i uninstalled the google toolbar and it worked. Now i just have to reinstall it and having it to show Jessicas site as it should. :dance:
Thanks everyone involved. :D
