I just sent up my webmail with neomail and sent a test email to myself and in the FROM BOX is says YOUR NAME
How do I change YOUR NAME to our companies name?
Any help will be very much appreciated.
Mike
When you ran it the first time you should have gotten a perferences box to set up the name, etc. You can change it by clicking on the little wrench icon on the tool bar under the drop down menu that says Inbox. That will allow you to change the name, add a signature, etc. Good luck.
