i just recently bought a plan on TCH, and i'm trying to use a 3rd party to software to connect to my mysql database, but i'm not sure of the parameters, eg hostname and port # to connect. can someone help me out pls.
Are you trying to connect from a remote system? If so, it's your domain name, and port 3306.
If you are connecting from your account, then 127.0.0.1, port 3306. Or you can use /tmp/mysql.sock.
I am trying to connect to MySQL from a remote system, my home comuter, using Navicat. I have entered the default port 3306, my Hostname, my username for my host, and the password that goes with the username. I also tried using the IP address also for my domain.
But still I get an error message saying "Access denied for user: 'myname@myhomeip' (Using password YES).
What am I doing wrong here?
I have defined some users in the Database, and even tried using those to login.
Thanks.
Martin
:blink:
You have to define which hosts your users can login from.
Also, keep in mind that database names and usernames are in the form of cpanelusername_dbname and cpanelusername_dbusername, respectively.
Edited by TCH-Raul
