Hi all,
I am trying to run lynx over ssh, and when I attempt to start it, ie. I type:
lynx
I get the following error:
Configuration file (null) is not available
I suspect that maybe this is an issue with permissions not allowing me access to the lynx config file.
Is there a fix for this?
Thanks,
Bob
The problem you are having is because the jailshell environment doesn't have a config file for lynx so lynx dies trying to find one.
For the majority of what you would do with lynx, though you don't really need a config file. You can just let it default everything. So do one of two things:
either run lynx with a cfg value: lynx -cfg=/dev/null
or create a file called .bash_profile in your home directory and put the following in it:
>LYNX_CFG=/dev/null
export LYNX_CFG
