Arta Posted January 20, 2004 Posted January 20, 2004 if you go to http://rt.artamishia.com/forum you can see the index of the forum, but when you click on any of the individual topics, it brings you to a white blank page. However, if you click to a post thread directly, you can get in, post and everything normally. I made a few modifications to files : posting.php, functions_post.php, viewforum.php, lang_main.php, posting_body.tpl, viewforum_body.tpl if anyone has any suggestions, it would be greatly appreciated! Thanks! Quote
TCH-Dick Posted January 20, 2004 Posted January 20, 2004 make sure you dont have any added spaces after your closing tags on the files you modified Quote
Arta Posted January 20, 2004 Author Posted January 20, 2004 that didnt help... any other suggestions? i'll probably end up reversing the mod Quote
TCH-Dick Posted January 21, 2004 Posted January 21, 2004 You most likely made an error when modding viewforum.php I would replace it then try the modifications again. Quote
Arta Posted January 22, 2004 Author Posted January 22, 2004 yes, that is where i made my mistake.. i found an extra ): } where it didnt belong, and didnt have the same set where it did belong... im terribly new at modifying my own php, still really learning based on reading through the pre-existing codes of phpBB and their mod database.. Thansk for the help! Quote
