Hi, All.
I'm trying to venture into the world of installing, customizing and learning more about IPB. I'm a little concerned about the extent of my abilities, since I can't even find the install link in cpanel. :dance: I found the "Bulletin Board" under cgi-scripts and accidentally installed phpBB instead.
Anyone willing to help me get started would be greatly appreciated.
Nevermind...I found it! Now...to delete the phpBB that I accidentally installed, can I just delete the "/forum" folder? Or is there another way to uninstall?
you can delete the forum folder, unless you went thru the set up process after you installed it there wont be a database created fro the phpbb. If you did go thru the setup, you can delete the database in manage mysql. Just make sure if you do have to delete the database...you delete the right one :)
Thanks, Mike. I did not go through setup, so I will delete the folder. I will also double check databases to make sure!! Thanks!
