godivad Posted December 30, 2003 Posted December 30, 2003 Everything appears to work except rebuild - it hangs. And then of course I can't see the site. Anyone have this problem and know the fix? Quote
charle97 Posted December 30, 2003 Posted December 30, 2003 are you running any firewalls or popup blockers? do you have javascript enabled? what's the url where you want your blog to appear? what's your present local site path? what's the url where you want your archives to be written? what's your present local archive path? Quote
godivad Posted December 30, 2003 Author Posted December 30, 2003 are you running any firewalls or popup blockers? No popup blockers. No firewalls. do you have javascript enabled? Yes - double checked to verify. what's the url where you want your blog to appear? since my DNS isn't prop'd yet, I used this address http://209.152.174.96/~godivad/path what's your present local site path? /home/godivad/public_html/path what's the url where you want your archives to be written? http://209.152.174.96/~godivad/patharc what's your present local archive path? /home/godivad/public_html/patharc Quote
charle97 Posted December 30, 2003 Posted December 30, 2003 do you get errors when you attempt a rebuild? are permissions for the path and patharc folders set to 777? Quote
godivad Posted December 30, 2003 Author Posted December 30, 2003 No errors. A window pops open, I select rebuild everything. Then it says rebuilding Individual pages 1-1... and then nothing else happens. I checked the permissions on path and patharc - both set at 777. everything else seems to work fine. I can make entries and edit them. Just the rebuild is the hangup. Quote
charle97 Posted December 30, 2003 Posted December 30, 2003 when you select rebuild site, choose indexes only. Quote
godivad Posted December 30, 2003 Author Posted December 30, 2003 tried that, same result. Here's another question. I ftp'd the gz.tar file to my public_html folder as per the instructions. the gz.tar file was 814kb, and ftp shows it as the same size. But in the file mgr, it shows 795kb. and when I extract the files, it does not have all the files. I unzipped the files then uploaded them. still don't know why the rebuild doesn't work. i downloaded another browser and made sure it did not have popups blocked. still rebuild hangs. arg Mad!!! Quote
godivad Posted December 30, 2003 Author Posted December 30, 2003 Charles, I got it working. I read on the MT site that Norton security might have something to do with blocking popup rebuilds or something like that, so I disabled it, rebuilt it and voila - it worked. geez, what a pain. Thanks for all your help and patience. Thumbs Up Quote
charle97 Posted December 30, 2003 Posted December 30, 2003 Charles, I got it working. I read on the MT site that Norton security might have something to do with blocking popup rebuilds or something like that, so I disabled it, rebuilt it and voila - it worked. geez, what a pain. Thanks for all your help and patience. Thumbs Up hmm. first question i asked too. Quote
