godivad Posted December 29, 2003 Posted December 29, 2003 Rock Sign my dns is not prop'd yet, so i'm not sure if this could be the problem, but anyhow, here's the situation. I uploaded MT full w/ lib. Changed the cfg file, did the mysql database and user stuff, changed password cgi file. mt-check.cgi went ok. but on mt-load.cgi, rec'd following: Connection error: Access denied for user: "****@localhost' (Using password: YES) Do I need to open a db directory? I've tried the user as just mtadmin, but that didn't work either. Quote
charle97 Posted December 29, 2003 Posted December 29, 2003 take a look at the first three steps listed here. Quote
godivad Posted December 29, 2003 Author Posted December 29, 2003 thank you charles. i saw my mistake. I had done those steps, but i had used a different user name in the cfg file than the username i made. duh. Thanks! Quote
