Are there any special settings that will optimize FTP uploads using CuteFTP Pro? Mine seems to upload very slowly and one file at a time. :P
TCH-Rob: Just moving to the correct forum.
Edited by TCH-Rob
Perhaps this info from CuteFTP's Help File could be useful:
CuteFTP’s Advanced settings can be accessed by choosing Edit > Settings > Advanced from the menu bar.
Receive/Send Buffer
This shows the size in bytes of transmission buffers.  Larger values may increase performance at the cost of higher RAM usage.
Transfer can also be slowed by firewall and antivirus software. In no way am I recommending that you disable those! Just check to see if there are any settings in those applications that may help matters.
Edited by TCH-Lianna
Thanks for the assistance.
CuteFTP Pro does not share this same menu structure. As far as I can tell, in CuteFTP Pro you are unable to alter the send/receive buffer settings.
  • 2 weeks later...
Silica, what kind of Internet connection are you using. Most DSL/Cable connections will advertize fast download speeds, but upload speeds will vary. For example, at home my DSL is 768k download, but only 128k upload.
-kw
