:lol: Hi folks.
I have an 1100 mhz with windows xp home.
I noticed that no matter if I install a 512, a 128, (2) 128 chips, or all three that system info reports double the amount of ram I installed.
I have 2 of the same pc's, both xp home, and my other reports them accuratelyj.
Does anyone have an explanation for this wacko behavior?
Do I have a bad motherboard or something?
thanks,
Mike
Is it possible you have ram on the motherboard? Some of the older ones I've seen do but I've not seen it recently. Take out the ramsticks and see what it says.
I tried it, Jim.
I get the series of 3 beeps, no boot up.
Possibly motherboard problem, but if so, I dont really know\
if it's causing any problems. Seems to work ok. Guess I better just
keep an eye on it.
thanks. Rock Sign
