Hey, all --
I want to run a simple cron job (it will check a POP account every 30 minutes for blog updates). The script is a Perl file, pop2blog.pl. I put it in my /public_html/cgi-bin directory and try to set up a cron job, but I get this error:
/bin/sh: /cgi-bin/pop2blog.pl: No such file or directory
The command I give Cron Manager to run is
I tried /home/akantor/public_html/cgi-bin/pop2blog.pl -- no luck.
What's the proper place for the Perl script and what's the proper command line for the Cron manager? Thanks for your help!
Andrew
As a follow up:
I tried moving the pop2blog.pl file to /home/akantor/pop2blog.pl but got the error
/bin/sh: /home/akantor/pop2blog.pl: /usr/local/bin/perl: bad interpreter: Permission denied
Any ideas? Help!
Getting better, but not quite. Looked like a permissions problem, but now I get:
Can't locate Mail/Box/Manager.pm in @INC (@INC contains: /usr/lib/perl5/5.6.1/i686-linux /usr/lib/perl5/5.6.1 /usr/lib/perl5/site_perl/5.6.1/i686-linux /usr/lib/perl5/site_perl/5.6.1 /usr/lib/perl5/site_perl/5.6.0 /usr/lib/perl5/site_perl .) at /home/akantor/pop2blog.pl line 18. BEGIN failed--compilation aborted at /home/akantor/pop2blog.pl line 18.
I feel like I'm so close to this! Help!
i'd rename pop2blog.pl to pop2blog.cgi and place the file in the cgi-bin. put
>/home/akantor/public_html/cgi-bin/pop2blog.cgi
in the command to run path. also, make sure that permissions are set to 755.
Yep, that's what I'm using. And I'm wondering if I'm missing any Perl modules. Any thoughts?
Go to your cpanel page and click on "Installed Perl Modules" ... if the module isn't listed, it isn't installed. If not submit a trouble ticket, and TCH may install it. I say "may", as the someone will review the module first before it will be installed.
jim
