TCH-Dick Posted November 1, 2003 Posted November 1, 2003 the file sm_install.php after install. When accessed from the browser it takes you to a page that says • Welcome! Welcome to the Invision Power Board Safe Mode Installer Before we go any further, please ensure that all the files have been uploaded, and that the file 'conf_global.php' has suitable permissions to allow this script to write to it ( 0666 should be sufficient ). You will also need your SQL database name, your SQL username, your SQL password and SQL host (usually localhost). Once you have clicked on proceed, you will be taken to a form to enter information the installer needs to set up your board. PLEASE NOTE: USING THIS INSTALLER WILL DELETE ANY CURRENT INVISION POWER BOARD DATABASE IF YOU ARE USING THE SAME TABLE PREFIX Proceed >> Is this something that needs to be deleted after install and is there any other files that need to be deleted after using the one-click install? Quote
TCH-JimE Posted November 1, 2003 Posted November 1, 2003 Always disable any update scripts by making them unwritable too (set them to 000 or something similar) And always do a backup too of your Mysql and pages Jim Quote
