I have a site that was created in Frontpage, when I try to upload it to a secure area the .cgi links don't work. When I fix them in Dreamweaver and upload them it seems the code changes back to the old link info. How is this possible? I was told by my service provider that Frontpage extentions are not allowed but that does'nt make any sense does it? here are the links to the sites. If you take a look at the unsecure site everything is there and that is what it should look like, but if you take a look at the secure site not everything shows up on the subpages(what is going on Will swithing isp solve my problem? Thanks in advance to everyone. :D
?)steelbuilt
steelbuilt secure
The view cart works because you reference it via:
>https://www.readysecure3.com/users/steelbuilt-inccom/cgi-bin/viewcart.cgi
However, you dont do the same with ordering buttons:
>form method="post" action="/cgi-bin/cart.cgi"
I am guessing this is your main problem. Also the images will need to be called via HTTPS rather then HTTP which at present is what your doing
Jim
Thanks. I will try to change the extentions in Front page. I have tried to change the extentions in Dreamweaver and they seem to go back to the old links once I update them. I will let youknow if it did this again.
Dreamweaver should leave the code alone, silly question, but are you uploading it to the same place? I have lost count of the number of times I have edited a p age, uploaded it (or so I thought) and seen the old page and gone into a flap because of it. I often upload it to the wrong folder or even website!
Jim
