Guest khagus Posted January 9, 2003 Posted January 9, 2003 If you have two domains registered, can you have both domains point to the same website if you purchase a Starter Plan account. Basically, no matter which of the two domains you put in a browser, it will take you to the same website that you have setup on your account. Thanks khagus Quote
orangechicken Posted January 10, 2003 Posted January 10, 2003 I don't believe so. What you could do is when you purchase the second domain you could have them set up domain forwarding and forward it to your real domain. I just don't think SNH allows for multiple domains to be parked on the same account - they have reseller accounts for that. Head Guru or someone else around here will be able to give you a definitive answer. Quote
