RickB Posted July 4, 2008 Posted July 4, 2008 Yes, I am a nuke dummy. I added the theme "Siteground" into the themes folder. I then selected preferences and selected Siteground as the theme. When I refreshed, it made the entire website blank. By using SmartFTP I figured out what I did wrong. When I unzipped the Siteground folder I did not look inside. Inside the Siteground folder is another Sitegroud folder with all the theme files. I manually deleted the Siteground "double folder" on the website and installed the singl theme folder. Refresed the site...still blank! I cannot get back to the Admin site because it too is blank. How can I manually reload my old theme? Thanks, RickB Quote
TCH-Bruce Posted July 4, 2008 Posted July 4, 2008 Sorry, never used Nuke. I'm sure someone will come by with a solution for you. Quote
nortk Posted July 4, 2008 Posted July 4, 2008 (edited) Do a google search for phpnuke blank theme. I found several similar hits. I imagine one is just what you need. Good luck! Edited July 4, 2008 by nortk Quote
JTD Posted July 9, 2008 Posted July 9, 2008 If you want to get back to the standard theme so your site will show. You will have to go into your database I believe it is the config portion and change it to whatever the standard theme is there. Quote
