For the past coupla days, I can't get into SquirrelMail. (Well, I did once for a few minutes.) I get this error:
ERROR : Bad or malformed request.
Query: FETCH 1,2,3,4 (FLAGS BODY.PEEK[HEADER.FIELDS (RECEIVED)])
Server responded: Command unrecognized: UID FETCH
I'm able to log into NeoMail and Horde no problem, and I don't have any trouble getting my mail with a POP client (Eudora, specifically). It's just SquirrelMail.
Any ideas? Thanks!
Andrew
One more note: I can compose new mail, view the folder-options screen, etc. -- in short, I can do everything but view the folder list (on the left) or my inbox (on the main frame).
  • 5 weeks later...
I'm having this problem right now. :) What is the solution? It is only on one of my e-mail accounts. The others work fine.
My message in the folder and message windows:
Query: FETCH 3,7,8,10,12 (FLAGS BODY.PEEK[HEADER.FIELDS (RECEIVED)])
Thanks.
