KnightMatrix Posted June 20, 2003 Posted June 20, 2003 when trying to add links or download links i get this error after installing php nuke is there a way to fix this · Affilates Warning: setlocale() [function.setlocale]: Passing locale category name as string is deprecated. Use the LC_* -constants instead. in /home/knightm/public_html/DCh/modules/Web_Links/index.php on line 772 Gamming each link i create or dowload link has the same problem Quote
TCH-Andy Posted June 20, 2003 Posted June 20, 2003 Try this link http://www.totalchoicehosting.com/forums/i...=ST&f=21&t=2746 Where Jimuni gives an answer Hi, Simple fix. Search through the mainfile.php file using ctrl+f in internet explorer and search for LC_Time When you have found it, it may look be "LC_Time" remove the quotes so its just LC_Time Remember to back this file up first! Andy Quote
KnightMatrix Posted June 20, 2003 Author Posted June 20, 2003 okay fix that had to edit every modules index.php they all was producing the same error there is 4 refernces to "LC_time" in each php file and replaced them all for save measures Quote
