Database error
Unable to connect to database host localhost. Check the database data entered in the setup form.
Can't continue!
Link Up - Installation
Set up these variables
If you don't have a mysql database, ask your server admin to create one for you
****Mysql database host (try "localhost" if you are not sure)
Your mysql database username name
Mysql database password pass
Name of your mysql database link
Prefix of all tables
Full path to the folder where the scripts reside. If this field already contains some value, this value should be correct, don't change it if you are not sure it is incorrect. No trailing slash.
Example for Linux: /htdocs/sites/user/html/folder_name
Example for Windows: C:/somefolder/domain.com/folder_name
The part that im stuck is where I have the asterisks..the sql db i made up is called link...after that I drew a complete blank....
Any insite, I know the Admin can go in and take a look at the mess I created...
TIA...
Edited by rbb213
Hello you need to set up the application to use the following.
replace cpaneluserid with your cpanel user id and this should allow your application to work.
servername = localhost
username= cpaneluserid_name
pass = pass
database = cpaneluserid_link
My database check list
-- databse connect ----
Be sure that in MySql you
1 - created the database
2 - created a user
3 -added the user to the database (go back to MySql and find the Add user
select the user and database, and then Add user to database)
Then to connect to the database in a script use:
host: localhost
database: yourCpanelName_databaseName
user: yourCpanelName_databaseUser
password: mypassword
* Note password is just as the password,
do not add the CpanelName to it.
2 - created a user
host: localhost
Thanks DON and Rob.....that was too easy...these instructions need to be pinned somewhere...lol
