I've had a couple of questions in the last week on the cgiemail script listed in the CGI Scripts section of cPanel. I thought it would be good to have a brief description to supplement the docs in helping to use the script on our servers.
First of all, when you click on the link you get a Using cgiemail page. I would recommend looking at the information in the links on this page for detailed help in using the program. This script is not actually installed into your directory, however. It is available on all servers in a directory that is linked to all users.
In the instructions you will see this line under the Actions explanation:
http://web.mit.edu'>http://web.mit.edu/wwwdev/cgiemail/questions3.txt
--------Part 1-------- ------------ Part 2 --------------------
Part 1 is optional but on our servers would be your domain. Part 2 consists of the location of the .txt file so in the example would be a file called questions3.txt in the /wwwdev/cgiemail directory in your public_html directory.
In your action you put the script location between these parts and on our servers it would be /cgi-sys/cgiemail. So your action string should include this string:
http://web.mit.edu/cgi-sys/cgiemail/wwwdev/cgiemail/questions3.txt
Here is an example of the html code called questions.html. (Change all the {} to <>)
<FORM METHOD="POST"
ACTION="http://www.domain.com/cgi-sys/cgiecho/scriptdir/questions3.txt">
Your e-mail address: {INPUT NAME="email"}{p}
Your name: {INPUT NAME="yourname"}{p}
Your quest: {INPUT NAME="quest"}{p}
Your favourite colour: {INPUT NAME="colour"}{p}
{INPUT TYPE="submit" value="Send e-mail"}
{/FORM}
And here is the questions3.txt file it calls (that would be in a script directory called /scriptdir in your public_html directory:
To: username@domain.com
Subject: Questionaire
What is your name?              [yourname]
What is your question?             [quest]
What is your favourite colour?  [colour]
Note the blank lines in the txt file. Also note that you can replace the cgiemail portion of the script with cgiecho to test the script. This will not email the information but print it on the screen.
Hope this helps you get started. The documentation has much more on using this script.
