Icurus Posted January 29, 2006 Posted January 29, 2006 I'm just getting started...got the basic's of building but this is a whole new world on this forum and website. If someone coulod answer my ? and Guide me to some beginner info that would be great. Thanks Icurus Quote
stevevan Posted January 29, 2006 Posted January 29, 2006 If you're asking for beginner info on web development, I would do a google search on the words "beginning web development". There are many informative sites out there. I would also look at some of the code behind your favorite sites (click on View, then View Source) and see what makes them tick. Then create a page off of your main site and play with the code and see how it affects things. Make notes on what you did and what worked and what didn't. (I've got a pretty thick folder of my "exploits"!) But that's where the fun of learning the internet is! For info on forums, the best source is the homepage for the forum developers. Hope this helps! Quote
TCH-Rob Posted January 29, 2006 Posted January 29, 2006 This may be a good start as well. http://www.make-a-web-site.com/ Quote
TCH-Don Posted January 29, 2006 Posted January 29, 2006 A book for beginners is a good way to start it will have more detailed information than will fit on a web site. Quote
1stchoice Posted February 21, 2006 Posted February 21, 2006 Just as Steve said, view source and Google. Try to find free things as an alternative to paying for tools and services. Quote
TCH-Tim Posted February 21, 2006 Posted February 21, 2006 Depending how much experience you already have, a book with step-by-step examples isn't a bad way to start. I generally use free online resources, but sometimes having the paper reference in your hand is so much easier. And "right-click and Google" can be intimidating for the newly initiated. Also, since you're just getting started, you might as well learn how to do CSS layouts and use PHP includes. Your life will be so much better for it. As always, we're here to help if you have questions. Quote
