It seems that your ftp server (ProFTPD) doesn't support resuming of file transfers.
I have tried using several ftp clients (CuteFTP, WS_FTP, and SmartFTP) all with the same results, I get the message back from the server saying "Append/Restart not permitted, try again.". Can you enable this feature please?
Thanks for your help! ;)
- Hurai
domain: hurai.com
server: server17
Your statement is not completely true. Our servers don't support resuming ftp uploads but they do support resuming ftp downloads.
It is possible for misuse of uploading and as a result resuming ftp uploads is by default turned off in the ftp server software. I have hosted here since January and have uploaded some pretty large files and never had any problems (other than the frustrating cap my ISP puts on upload speeds.) I actually had to test and insure that ftp download resume was possible since I don't ever recall having to use it.
If you are having problems with uploads you should check and be sure you are using passive mode.
