I'm trying to allow members of my forum to sign in from the pages of my website. I'm pretty sure I have the php coding correct, it just isn't working. I know very little about what I'm doing so any help is MUCH appreciated.
Heres my problem:
I sign with a correct user name and password and when I hit the log in button it just dumps me right to my else condition as if I weren't logged in. My code is:
Session Management that is at the top of both the page i'm logging in from and the page I want to go to after a log in.
define('IN_PHPBB', true);
$phpbb_root_path = './forums/';
include($phpbb_root_path . 'extension.inc');
include($phpbb_root_path . 'common.'.$phpEx);
// Start session management
$userdata = session_pagestart($user_ip, PAGE_INDEX);
init_userprefs($userdata);
// End session management
my forums are located in my forum directory so that part is correct.
then on the page you get taken to after a log in i have:
if( $userdata['session_logged_in'] )
<html content>
else
echo('Please Login');
my syntax seems to be correct I just can't get the log in to actually work.
my form code that I'm logging in with is. (exactly as it appears on the page)
<form action="login.php" method="post"><font color=white face=verdana size=2>Username:</font></td>
<td width=140><input type="text" name="username" size=15> </td>
</tr>
<tr>
<td width=30><font color=white face=verdana size=2>Password:</font></td>
<td width=140><input type="password" name="password" size=15 ></td>
</tr>
<tr>
<td width=60></td>
<td>
<input type="submit" value="login" name="login"></form>
I've hit a major wall as I have no idea on where to go from here so any help would great.
Thanks in advance.
Welcome to the forums timmy
Sorry, I have never tried to login to any BB software other than from the BB interface.
Maybe one of our members has done this and can give you some clues.
The only issue I can see is your form action, maybe.
Is the page you are trying to login from in the forums directory?
If not then you need to change
></pre>
to
></pre>
<form action="location%20of%20forums/login.php" method="post"><
to
><form action="location of forums/login.php" method="post">
my file structure is
public_html
--index.php (page logging in from)
--login.php
forums
--index.php (forums index)
p.s - thanks for the welcomes guys. been a customer for awhile now, just never posted.
Edited by timmy
ok i got it workin. I reinstalled my forum and it worked. so now my next question is how do I change it so when a user logs in they are taken to a page within my site instead of the forum?
