Hello,
I have constructed the entire form within flash and set up the following function for sending the form:
function sendForm () {
my_lv = new LoadVars();
my_lv.flname = _parent.name_txt.text;
my_lv.email = _parent.email_txt.text;
my_lv.specialist = _parent.specialist_txt.text;
my_lv.themessage = _parent.message_txt.text;
my_lv.send ("??????", "???????");
nextFrame ();
I dont know to put for the bold ?'s
If anyone could help Id really appreciate it!
Thanks
Welcome to the forums, Bennett. While I don't use Flash (like to learn it, tho! :thumbup1: ), be patient...one of the flash guru's should be along to answer your question.
Something along the lines of,
Depends on how you want to process it.
I looked around for information and came up with this but it will not work either:
// Submit Button action
submit_btn.onRelease = function() {
//Add Path of the php file
feedbackpath = "mailto.php";
str1 = email.indexOf("@");
str2 = email.indexOf("@")+1;
str3 = email.charAt(str1+1);
str4 = email.lastIndexOf(".");
str5 = email.charAt(str4+1);
len = length(email);
counter = 1;
flag = 0;
while (Number(counter)<=Number(len)) {
Char = substring(email, counter, 1);
if (Char ne "@") {
flag = Number(flag)+1;
counter = Number(counter)+1;
submit_btn.onRelease = function () {
if (flname_txt.text == "" || email_txt.text == "" || themessage_txt.text == "" ) {
status_txt.text = "Please complete the entire form ...";
} else {
status_txt.text = "";
loadVariablesNum(feedbackpath+"?name="+name+"&email="+email+"&feedback="+suggestion, 0);
gotoAndStop(63);
any suggestions would he helpful
  • 3 weeks later...
do you have a mailto.php file?
yeah i figured it out - thanks
