paonza Posted October 6, 2005 Posted October 6, 2005 Hi All! I have purchase a SSL certificate for a domain, example www.mydoamin.com Now I open a subdomain: sub1.****. I will expect to use the SSL cert bought for the "www" domain on the subdomin with a warning message. But this doesn't work! If I try to access to https://sub1.****/page.htm the server redirect this request on https://www.****/page.htm Is it correct or the cert isn't well installed? what do you think about? ciao Fabio Quote
TCH-Rob Posted October 6, 2005 Posted October 6, 2005 Fabio, Welcome to the forums. The cert was installed as it should have been. There are different kinds of SSL certificates. Most people use a regular certificate and it is good for only the main domain. Another type of cert is called a wildcard and it allows you to secure subdomains as well. The cost associated with a wildcard SSL is also several times the const of a regular SSL. Quote
abinidi Posted October 6, 2005 Posted October 6, 2005 Welcome to the forums Fabio. With the information that TCH-Rob gave you, I'd just add that since your subdomains are all folders under your WWW (i.e. public_html) folder, you can still point people to your sub domain, but make your links to your secure content leave the subdomain. So if you have a place called shopping.example.com, all your content resides in a folder called: public_html/shopping/ So, when you want to direct people to the secure part of that subdomain, just send them to the https://www.example.com/shopping/ location, and it will work fine. That way you can have the less-expensive certificate, and you can still have people use your subdomains as entry points to your content. Just a thought. YMMV. -Paul Quote
paonza Posted October 6, 2005 Author Posted October 6, 2005 Hi All guys! Paul, your solution should be great! Let me try and i'll back to tell you the restults! thank you very much! Fabio Quote
