spongie93 Posted September 2, 2005 Posted September 2, 2005 since i noticed that tch people seemed to know more about coppermine, i decided to switch over to coppermine, all because of thumbnailing. #1: i'm having a bit of trouble just uploading the pictures. it says The previous file could not be placed. You have successfully placed all the files. so i am pretty confused. #2: how do you install imagemagick? if you don't know, i can try gd. can gd support gifs? and if you know how to install gd for coppermine, please tell. thanks so much! Quote
TCH-Rob Posted September 2, 2005 Posted September 2, 2005 You do not need to install imagemagick, it is already on the servers. What did you use as its path? Quote
TCH-Don Posted September 2, 2005 Posted September 2, 2005 I think the way to install is to accept GD as the default then after install go into the config and select Imagemagik using the path /usr/local/bin/ Quote
TCH-Thomas Posted September 2, 2005 Posted September 2, 2005 I believe the the #1 is a permission problem. Make sure all the album folders have the correct permission (including the ones you eventually have set up yourself). Quote
