jmack772003 Posted August 26, 2005 Posted August 26, 2005 I am having trouble with a header.inc.php file. It requires that all variables (ie. databasename, user, passwd, host) are entered into an array. when I simply assign strings and connect to database,, it works. but know in an array format it continues to say that Error: You must set your correct database access info in `inc/header.inc.php`. but I am pretty sure the syntax is right. Unless synta is different for an array. this is what I have: <?php // Bold is changed //just to simplify N= name $db = array('host' => 'localhost', 'user' => "cpnelN_userN", 'pass' => "XXXXX", 'name' => "cpanelN_databaseNdb" ); $db['prefix'] = 'dotsilver_'; $mysql = new MySql( $db ); $mysql -> connect(); $_conf = $mysql -> get_conf_array(); $mysql -> close(); if( $_SERVER['QUERY_STRING'] != 'first') foreach( $_conf as $value ) { if( !$value ) Header('Location: configs.php?first'); } $_dir = array ( '0' => $_conf['home_dir'], 'inc' => $_conf['home_dir'].'inc/', 'smarty' => $_conf['home_dir'].'smarty/', 'layouts' => $_conf['home_dir'].'layouts/', 'langs' => $_conf['home_dir'].'langs/', ); $_site = array( 'pid' => $_conf['site_ID'], 'layout' => $_conf['layout_name'], 'theme' => $_conf['color_theme'], 'app_name' => 'dating', 'bizname' => $_conf['bizname'], 'brand' => $_conf['brand'], 'mail_support' => $_conf['mail_support'], 'mail_links' => $_conf['mail_links'], 'mail_info' => $_conf['mail_info'], 'mail_ads' => $_conf['mail_ads'], 'age_start' => 18, 'age_end' => 75, 'online_time' => 10, ); $_sock = array( 'domain' => 'dating-remote.dotsilver.com', 'domain_img' => 'dating-img.dotsilver.com', ); $_url = array( 'site_url' => $_conf['site_url'], 'site' => $_conf['site_url'], '_remote_lc_img' => "http://{$_sock'>http://{$_sock['domain_img']}/photo.php", '_remote_lc_img_up'=> "http://{$_sock['domain_img']}/photo_up.php", 'flash_server' => 'rtmp://dotsilver.com/', 'im_xml' => 'http://dating-im.dotsilver.com/', 'anti_scam' => 'http://www.dotsilver.com/antiscam/public/dating/', 'faq_scammers'=>'http://www.dotsilver.com/antiscam/' ); $_url['js'] = $_url['site'].'inc/js/'; $_url['member'] = $_url['site'].'member/'; $_url['layouts'] = $_url['site'].'layouts/'; $_url['tour'] = $_url['site'].'tour/'; $_url['img'] = $_url['layouts'].$_site['layout'].'/themes/'.$_site['theme'].'/img/'; $_url['image_upload'] = "{$_url['site_url']}member/photos.php"; $_langs = array( 'English', ); ?> Quote
carbonize Posted August 26, 2005 Posted August 26, 2005 The array format is correct but I would have to see the actual script that connects to be able to help more. Possibly a file called sql.class.php Quote
jmack772003 Posted August 27, 2005 Author Posted August 27, 2005 Carbonize, I appreciate you takin a look at this for me. here is that file, it is called db_funcs.class.php. I am know expert but it seems like it is calling the ($db)array correctly......do you think I could have done something wrong in the input of connection strings(in the header)? maybe 'localhost' doesn't work in an array? I don't know. but here it is....and thanks again: class MySql { function MySql( $db ) { $this->host = $db['host']; $this->user = $db['user']; $this->pass = $db['pass']; $this->name = $db['name']; $this->prefix = $db['prefix']; } function connect() { $host = $this->host; $user = $this->user; $pass = $this->pass; $name = $this->name; @mysql_connect($host, $user, $pass)or die( '<code><b>Error:</b> You must set your correct database access info in `<b>inc/header.inc.php</b>`.' ); mysql_select_db($name)or die( '<code><b>Error:</b> You must set your correct database access info in `<b>inc/header.inc.php</b>`.' ); } function query( $query ) { return mysql_query($query); } function fetch_array( $result, $type = MYSQL_ASSOC ) { return mysql_fetch_array( $result, $type ); } function close() { mysql_close(); } function get_conf_array() { $prefix = $this->prefix; $result = $this->query( "SELECT name, value FROM `".$prefix."config`" ); if( $result ) { while( $row = $this -> fetch_array( $result ) ) { $_conf[$row['name']] = $row['value']; } } elseif( $_SERVER['QUERY_STRING'] != 'first' && $_SERVER['QUERY_STRING'] != 'action=save') { Header( 'Location: configs.php?first' ); exit; }; return $_conf; } } ?> Quote
carbonize Posted August 27, 2005 Posted August 27, 2005 Your array is correct but it is saying some of the information you supplied is wrong. Quote
jmack772003 Posted August 27, 2005 Author Posted August 27, 2005 (edited) got it ...you were correct...on array for database I added the "db" to the end . it was rejecting it.....of course now I get a new message from configs file.....what does Warning: Cannot modify header information - headers already sent by (output started at /home/alcfuo/public_html/DRV/inc/header.inc.php:97) in /home/alcfuo/public_html/DRV/configs.php on line 348 mean? sorry...it is supposed to call file from my directory to install...if that help. Edited August 27, 2005 by jmack772003 Quote
carbonize Posted August 27, 2005 Posted August 27, 2005 That means that the script needs to be the very first thing on the page before any HTML or any other scripts. Quote
TCH-Don Posted August 27, 2005 Posted August 27, 2005 Look for any lines that have a blank space before the code is run or before going into php, thats the normal cause. Quote
