Slight Problems
Bam
Warning: Cannot modify header information - headers already sent by (output started at /home/myaccount/public_html/wp-config.php:23) in /home/myaccount/public_html/wp-login.php on line 7
Warning: Cannot modify header information - headers already sent by (output started at /home/myaccount/public_html/wp-config.php:23) in /home/myaccount/public_html/wp-login.php on line 8
Warning: Cannot modify header information - headers already sent by (output started at /home/myaccount/public_html/wp-config.php:23) in /home/myaccount/public_html/wp-login.php on line 9
Warning: Cannot modify header information - headers already sent by (output started at /home/myaccountpublic_html/wp-config.php:23) in /home/myaccount/public_html/wp-login.php on line 10
Warning: Cannot modify header information - headers already sent by (output started at /home/myaccount/public_html/wp-config.php:23) in /home/myaccount/public_html/wp-login.php on line 11
Warning: Cannot modify header information - headers already sent by (output started at /home/myaccount/public_html/wp-config.php:23) in /home/myaccount/public_html/wp-includes/pluggable-functions.php on line 151
Warning: Cannot modify header information - headers already sent by (output started at /home/myaccount/public_html/wp-config.php:23) in /home/myaccount/public_html/wp-includes/pluggable-functions.php on line 152
Warning: Cannot modify header information - headers already sent by (output started at /home/myaccount/public_html/wp-config.php:23) in /home/myaccount/public_html/wp-includes/pluggable-functions.php on line 129
this is after the install and i log in any ideas?
Edit: TCH-Bruce - removed account info for security reasons
the links are referring to *.html such as index.html, it should be php
lemme give more info:
if you type in thegrinder.ws it redirects you to thegrinder.ws/index.html, page not found(this is correct) but change the html to php and no problems, so what did I screw up?
Edited by Bam
I went to "thegrinder.ws" (nice theme, by the way), and all the links I clicked on worked fine. I didn't have any trouble being directed to any .html pages.
I tried firefox and IE.
Have you tried using a different computer or clearing your cache?
my redirector was set up improperly, now I just have to figure out how to edit my themes(thru the built in editor), it says if this file was writable you could edit it, but my permissions for the theme files are set properly, any ideas?
I tried to edit my themes using the built-in theme editor, and I was never happy with the result. I found it easier to use the "edit file" link in the cPanel File Manager to edit the theme files.
Plus, you run a security risk, allowing all your theme files to be writable. Somebody with bad intent could totally hijack your site. So it is much safer to update in cPanel (or to even download, edit, then upload your files).
That's my 2cents, which is seemingly worth less and less (especially at the gas pump!)
