julie Posted August 12, 2005 Posted August 12, 2005 Hi - For awhile, i've been running 2 blogs on my space, one with www.mywebsite.com and one with www.mywebsite.com/otherblog I decided I wanted to start keeping separate stats for the 2, so I wanted to make the second one a subdomain. I created the subdomain and changed the address information in my Movable Type setup so now it is otherblog.mywebsite.com. Is this ok that I created the subdomain after the folder already existed or is it going to mess things up with stats, etc? Thanks! Quote
TCH-Rob Posted August 12, 2005 Posted August 12, 2005 It may not function as you want it to. I would rename the otherblog folder, delete the subdomain in cPanel. Re-add the subdomain in cPanel, delete the folder it creates and rename the otherblog folder back to what it was. Quote
