Hello everyone! :)
I have a problem with date and time of my new Guestbook script.
Here is my Guestbook: http://shinydust.net/guestbook
The problem is Mysql timezone, which results in function "datetime" in MySql Guestbook database, and appears near every entry.
I suppose the reason is that your server (mine is Server92) are located in USA, while I'm italian: so default timezone is wrong for Italy.
For example: as you can read, in last "Sciapy" entry date and time displays now 13/07/2005 23:53.
That's because I've changed the time manually in the database. ^_^''
First, when she posted in my Guestbook, default date and time was: 13/07/2005 17:53
I'm sure it's your timezone server.
But in my Guestbook I'd like to display GMT date and time for Europe, particularly italian date and time.
How can I do this?
Is there a way to change timezone in Cpanel or MySql database?
I've searched for an option, but didn't find nothing. :(
Otherwise, is there a special timezone table to add in the database, or a special code to display in my pages which modifies default timezone with the italian one?
Please, help me. ^_^
Many thanks in advance, bye bye! :D
:tchrocks:
The server time is in the time zone which is correct for the server. If your time zone is different, then you need to modify the code to allow for that.
Most php code allows you to set a time zone in the admin / config (in the same way as you can set your time zone on this server, so it's correct for you).
I don't think the guestbook you are using allows for that, so you will need to look in the source code where it gets the time (template-tags.php), and modify the line to take account of the different time zone for you. For guestbook I think you will need to add "3600*X" where X is the numbers of hours shifted in time zone (6 in your case).
Alternatively you may be able to use the "putenv" function to set the time zone in php for that sccript.
Thanks for your fast and nice reply! :tchrocks:
I'll try to modify the PHP code, as you suggested me.
Hope to manage it! ^_^''
I'll let you know if there are other problems.
Bye, have a nice day! :*
Minhea
Uhm... I think I'm really confused. ^_^
This is more complicated then I expected. :)
In template-tags.php I've found this datetime string:
function entry_time($format='F jS, Y g:i A') {
global $entry;
echo date($format, strtotime($entry['date']));
Is this what is needed to me, the right place to add the timezone difference?
And where do I have to add that "+6*3600" string?
I've tried to add it after function $format, then tried to post.
But nothing changed at all. o_O'
Someone help me, please... I'm only a PHP novice. :D
Thank you!
EDIT:
I've modified the string in this way:
global $entry;
echo date($format, strtotime($entry['date']))+3600*6;
Something strange happened: now all my dates appeared something like this 21607
Creepy. :tchrocks:
Sigh! :(
Edited by Minhea
Try
function entry_time($format='F jS, Y g:i A Z21600') {
global $entry;
Z is offset for time zone
21600 is 3600x6
Zvalue to make the time zone more
Z-value to make the time zone less
I think that will work.
Minhea, you almost had it! :flex: The time offset you're trying to add needs to be inside the outermost parenthesis:
>echo date($format, strtotime($entry['date'])+3600*6);
*__*
Thank you so much, both of you, for replying me! :yes:
I think I should have understand... I' ll try your script later, then I'll told you if it works in my GB.
Thanks again! :)
WEEEH... David, you were right: I've modified the string as you told me, and now the date is the italian one!!! :)
I'm happy! :D
Thank you so much! :yes:
Bye everyone, have a nice week-end! ^_^
  • 1 month later...
Hi!
I have a problem similar to Minhea. I live in Sweden and i'm reconfiguring a guestbook. I use MySQL and PHP.
This is the code:
>Written by <strong><?php entry_smart_name(); ?></strong> on <?php entry_time('F jS, Y'); ?> at <?php entry_time('g:i A'); ?>
And this is what it print out:
>Written by Tiffany on August 17th, 2005 at 2:35 PM
Sure, that's exactly what it should print out. But since i live in sweden that date-syntax is wrong.
I want it to print out lite this:
>Skrivet av Tiffany den 7e Augusti, 2005 klockan 14:35 PM
I need all the help i can get, my PHP and MySQL skills aren't very good. Thanks in advance
/Henrik
Welcome to the forum, Henrik.
Nice to see another Swede in the forum. :)
Unfortunately I don´t know the answer to this but hang in there and someone will know the answer.
Welcome to the forum :)
Instead of the line;
try
>Skrivet av <strong><?php entry_smart_name(); ?></strong> den <?php entry_time('F jS, Y Z21600'); ?> klockan <?php entry_time('g:i A Z21600'); ?>
The alternative route, I think, is to use
><?php setlocale('LC_TIME','swedish'); ?>
before this line.
Do you also want the month to be in Swedish?
Thank you guys!
try
before this line.
When i tried:
It gave me:
Skrivet av Tiffany den August 17th, 2005 720021600 klockan 12:35 PM 720021600
So that didn't work at all
I also tried:
>Skrivet av <strong><?php entry_smart_name(); ?></strong> den <?php setlocale('LC_TIME','swedish'); ?><?php entry_time('F jS, Y'); ?> klockan <?php entry_time('g:i A'); ?>
But it didn't make any difference att all from how it were before. This is how the whole file looks like;
><div class="entry" id="<?php entry_id(); ?>">
<p class="entrymetadata">
Skrivet av <strong><?php entry_smart_name(); ?></strong> den <?php entry_time('F jS, Y'); ?> klockan <?php entry_time('g:i A'); ?>
</p>
<?php entry_comment(); ?>
</div>
Any ideas? :)
Welcome to the forums, Henrik! :)
Using setlocale('LC_TIME','swedish'); localizes output only of the strftime() function, not the date() function.
In order to localize your dates, you'd need to alter the entry_time() function to something like this:
>function entry_time($format='%B %e, %Y %H:%M') {
global $entry;
setlocale(LC_TIME,'swedish');
echo strftime($format, strtotime($entry['date'])+3600*6);
Then you could use code like the following:
>Skrivet av <strong><?php entry_smart_name(); ?></strong> den <?php entry_time('%e %B, %Y'); ?> klockan <?php entry_time('%H:%M'); ?>
...which should produce the following output:
Skrivet av Tiffany den 17 augusti, 2005 klockan 20:35
That's about as close as I could make it to what you want without a significant amount of programming.
Hope this helps...
