I have set up a forum using SMF 1.0.3 here.
On the attached image you see the top of it.
I would like to get rid of the text in the red part and then "stretch" the logo in the green part so it is across the whole page (the logo itself is 750 px)
In which page and what part of it do I modify and finally (since Im no good at php), what exactly do I write, if the logos name is smflogo.gif if and I use the default theme?
Any help greatly appreciated. :notworthy:
Sorry, Thomas, I never used SMF so I can't help you much but if you can't figure it out, let me know (PM or IM me) and I'll download it and take a look.
If you go into Themes > Default
and find index.template.php
in that file look for the body tag
just below is the table cell that displays first.
thats the area the change.
Assuming you are using the default theme.
Thomas, goto Cpanel>file manager. Open the directory where you installed SMF and find Themes. There are 2 choices classic or default, pick the one you are using. Then look for a file called index.templates.php and open it. Scroll down until you get to
></head>
<body>';
If you want to put in a new header just place your html under this.
To replace an existing logo scroll down to
//The logo and three info boxes//
and change the coding for the new logo.
An example of a new header and changed info boxes on my site is here
Edited by curtis
></head>
<body>';
Ok, found "//The logo and three info boxes//", however, after that I found a part saying "// This part is the logo and forum name. You should be able to change this to whatever you want...", so I assumed it was there I would tell where to find my logo since it was the place I found /smflogo in the originalfile but I get a blank page with this text:
This is here because Gecko browsers properly support white-space.... if ($context['browser']['is_gecko']) echo ' '; echo ' '; /* Internet Explorer 4/5 and Opera 6 just don't do font sizes properly. (they are big...) Thus, in Internet Explorer 4, 5, and Opera 6 this will show fonts one size smaller than usual. Note that this is affected by whether IE 6 is in standards compliance mode.. if not, it will also be big. Standards compliance mode happens when you use xhtml... */ if ($context['browser']['needs_size_fix']) echo ' '; // Show all the relative links, such as help, search, contents, and the like. echo ' '; // If we're viewing a topic, these should be the previous and next topics, respectively. if (!empty($context['current_topic'])) echo ' '; // If we're in a board, or a topic for that matter, the index will be the board's index. if (!empty($context['current_board'])) echo ' '; // We'll have to use the cookie to remember the header... if ($context['user']['is_guest']) $options['collapse_header'] = !empty($_COOKIE['upshrink']); // Output any remaining HTML headers. (from mods, maybe?) echo $context['html_headers'], ' '; // Because of the way width/padding are calculated, we have to tell Internet Explorer 4 and 5 that the content should be 100% wide. (or else it will assume about 108%!) echo '
So I am probably missing something. Do I need to delete, add something?
Thomas to get rid of the text in the red part:
Goto your forum and sign-in as admin. Left menu go down to Forum Configuration
and click Edit Server Settings. When server settings opens go down to
Message Board Name and delete whatever is in the box. In your case that would be Marve Assistans Forum.
After that text is removed you should be able to adjust the size of your image to the size you want.
Did that, but still getting this text described above. :huh:
Here is what that part of index.template.php says:
>// The logo and the three info boxes.
echo '
 <table cellspacing="0" cellpadding="0" border="0" align="center" width="100%" style="position: relative;">
	 <tr>
   <td colspan="2" valign="bottom" style="padding: 5px; white-space: nowrap;">';
echo '
  	 <td align="center" width="750"><img src="http://marveassistans.se/smflogo.gif" alt="" /><br />
<br />
  	 <span style="font-family: Georgia, sans-serif; font-size: xx-large;">', $context['forum_name'], '</span>';
echo '
   </td>
The problem is
><br />
<br />
Try removing it and just use
<tr>
   <td align="center" >
<a href="http://marveassistans.se">
<img src="http://marveassistans.se/smflogo.gif" />
</a>
</td>
I added a link to home page on the logo.
Works better. Now there is no white space but the logo is way too much to the right even if it as far as I can see should be centered.
But we are getting close. :huh:
Ok, here´s what I did...
I changed Bruce suggestion so it adds Dons suggestion about align="center", so now it looks like this:
<a href="http://marveassistans.se"><img src="http://marveassistans.se/smflogo.gif border=0" /></a>
</td>
This way no logo shows in either I.E or FF but if I remove border=0", it looks as it should in FF but have the blue border in I.E.
Shall the
be there anyway?
My mistake Thomas
<a href="http://marveassistans.se"><img src="http://marveassistans.se/smflogo.gif" border="0" /></a>
</td>
