webgyrl Posted April 15, 2005 Posted April 15, 2005 Hi gang, I have run into the strangest error with a design I am working on and I am hoping someone out there can shed some light on the matter. I have a new layout that I have designed in Photoshop and then sliced in Fireworks and exported to Dreamweaver. In Dreamweaver I have made this design a template and have been testing pages created from the template. Everything was going smoothly until I added in my CSS stylesheet link using the following code: ><link rel= "stylesheet" type="text/css" media="screen" href="http://www.natfunkmusic.com/mbstia/styles/main.css" /> When I test the design in the IE 6 and Firefox browsers with the stylesheet linked: http://www.natfunkmusic.com/mbstia/test.htm There is a one pixel line running along the top of the page and down the side. When I take the stylesheet out, the design is fine and that one pixel line at the top and right side is gone: http://www.natfunkmusic.com/mbstia/testnocss.htm Is there any explanation for this behavior? I can't for the life of me figure it out. Thanks Quote
TweezerMan Posted April 15, 2005 Posted April 15, 2005 The line at the top is a 1px tall table row, filled with your transparent spacer.gif. The line on the right is a 1px wide table column, also filled with your transparent spacer.gif. These are showing as white lines, because in your stylesheet: >table { background-color: #ffffff; } ...your table has a white background, which is showing through the transparent spacer.gifs. Change the background color of the table to match the page's background color: >table { background-color: #01547c; } ...and that should make the lines go away. Hope this helps... Quote
webgyrl Posted April 24, 2005 Author Posted April 24, 2005 David! Thank you so much for pointing that out. That was the culprit. Sometimes you just can't see the forest for the trees.... errr or the CSS! Thanks again Quote
TCH-Don Posted April 24, 2005 Posted April 24, 2005 Nat, you probably did this, but when using tables it sometimes helps to turn on the table border, or even setting the table background color to a bright color. Or if you have firefox web developer extension you can use it to see the table and cells. Quote
webgyrl Posted April 24, 2005 Author Posted April 24, 2005 Don, You know, I didn't actually do that with this design because of the zillion slices I make in Fireworks to export to Dreamweaver. I do usually use that technique, but when there are a lot of slices it usually renders the design all funky in the DW view. What's the Firefox extension and where can I get it? Thanks Quote
GroovyFish Posted April 24, 2005 Posted April 24, 2005 Hi Nat, You can get the Firefox Web Developer Extension here: http://chrispederick.com/work/firefox/webdeveloper/ Quote
TCH-Don Posted April 24, 2005 Posted April 24, 2005 When you have the extension, goto tools > web developer > outline and select tables or cells. Quote
webgyrl Posted April 24, 2005 Author Posted April 24, 2005 Ok Wow... I just found a whole buncha goodies! Thanks for the heads up on those guys. Man, Microsoft had better come up with something REALLY good to compete with what Mozilla is doing. It's a pitty we even have to make our sites IE "friendly". Oh well. Quote
