Miriam Posted December 1, 2004 Posted December 1, 2004 I originally created a domain (main.biz) and then created domain1.main.biz and domain2.main.biz on the server. All three (main.biz, domain1.com, and domain2.com) are registered domain names. It was then set up so that when someone typed in domain1.com, they would be sent to domain1.main.biz and that is what would show in the url address bar. Everything was working fine. Then the client decided he wanted everything separate. So I disengaged domain1 and domain2 from main.biz. They now are separate accounts and are reached at domain1.com and show domain1.com in the url address bar. That's working fine also. domain1 and domain2 are still physically located in the main.biz directory as separate folders. So the paths are: public_html/domain1/ public_html/domain1/ within the main main directory. Now my problem is that the original addresses of domain1.main.biz and domain2.main.biz have been spidered and are listed in the search engines. When these old links are clicked, they still work and go to domain1.main.biz and domain2.main.biz, that is what shows in the url address bar. I need to write an Apache ModRewrite in the .htaccess file of main.biz which will redirect any requests for domain1.main.biz to domain1.com and domain2.main.biz to domain2.com. I have read the rewrite rules and have tried to write them, but I don't understand what I'm doing and it doesn't work. Can someone please help me write the rules correctly? Thanks so much, Miriam Quote
TCH-Rob Posted December 1, 2004 Posted December 1, 2004 Miriam, are you a reseller? Checking to make sure because it is against AUP to point a domain name to s subdomain or sub folder. Quote
Miriam Posted December 2, 2004 Author Posted December 2, 2004 Yes, I'm a reseller. I got the problem sorted out and everything is pointing where it should. Whew. Quote
TCH-Don Posted December 2, 2004 Posted December 2, 2004 Glad to hear it. Is it something you can share in case others run into this. Quote
Miriam Posted December 2, 2004 Author Posted December 2, 2004 I submitted a help ticket, and someone in support was kind enough to create this .htaccess file for me. The one for domain1 was placed in the domain1 folder, and the one for domain2 was placed in the domain2 folder. /domain1 >RewriteEngine on RewriteCond %{HTTP_HOST} ^domain1.main.biz$ [OR] RewriteCond %{HTTP_HOST} ^www.domain1.main.biz$ RewriteRule ^(.*)$ http://www.domain1.com [R=301,L] /domain2 >RewriteEngine on RewriteCond %{HTTP_HOST} ^domain2.main.biz$ [OR] RewriteCond %{HTTP_HOST} ^www.domain2.main.biz$ RewriteRule ^(.*)$ http://www.domain2.com [R=301,L] I've been trying to study this code to try to understand what the different parts mean, but I'm not there yet. Part of my problem occurred when I got very confused about what to do with the subdomains I had originally added in the main.biz control panel. And the re-directs I set up. Originally, everything worked. But when the client asked me to separate everything, I deleted the redirects, and I deleted the subdomains. That caused problems, and I finally figured out I had to put them back so I could redirect them and then the rewrite worked. I'm still confused, but it's working. Quote
