kfosterm Posted November 27, 2004 Share Posted November 27, 2004 I'm not suse if this is the correct forum, but perhaps someone here can eith help or point me in the right direction. I've already looked for help on the MT forums, but thought I'd check here in case this is an issue with MT installed on TCH servers. Any help would be greatly appreciated. I recently upgraded from MT2.61 to MT3.12. All went well. Now I'm trying to convert from BDB to mysql, and when I run the mt-db2sql.cgi I get the following error: >Loading database schema... Loading data... MT::Author 1 MT::Blog 1 10 11 12 7 8 MT::Category 10 14 16 17 18 19 21 22 23 24 25 33 34 35 36 37 38 39 40 41 42 43 44 45 An error occurred while loading data: That's it. Everything just stops. Has anyone else had this problem and found any resolutions? Thanks. Quote Link to comment Share on other sites More sharing options...
borfast Posted November 28, 2004 Share Posted November 28, 2004 Sorry, I don't use MT, so I really can't help you I do know we have some MT users aboard, so they may be able to help you. Doesn't MT have some support forums where you may look for the answer to the problem? I know MT moved to a commercial license when they bumped their version to 3.0, so the forums are probably for the commercial clients... :\ Quote Link to comment Share on other sites More sharing options...
TCH-Rob Posted November 28, 2004 Share Posted November 28, 2004 A google search of "Movabletype Berkely db To Mysql" got me; http://www.uberdose.com/kbase/berkeley-db-to-mysql/ MT's version of the upgrade Those were the first two, you might find more along the way. Quote Link to comment Share on other sites More sharing options...
