Wondering if anyone could help me.
I was trying to do something like this...
talking about the black rectangle on the bottom with text.
So I started experimenting with imagemagick using the scripts from the following site, but some don't work at all and others just work partially.
http://www.cit.gu.edu.au/~anthony/graphics...ating/#labeling
In particular, I'm looking at the Splice and Draw and the Append and Draw.
The splice and draw doesn't work at all, and the append and draw just drew the yellow box, but didn't write the text on it. ie -> http://section31.us/upload/blah.jpg
Has anyone tried doing something like this. I know its not my syntax, since i was able to do other stuff with imagemagick.
Edit: it looks like i found the problem... it appears the image magik version u have installed isn't up to date. Those scripts were for version 6. I used these scripts for version 5 and they worked fine... ;) :dance: http://www.cit.gu.edu.au/~anthony/graphics...ating/#labeling
someone may want to update this page, the tutorials are dated or dead.
http://www.totalchoicehosting.com/help/id161.htm
