allaboutmadonna.com Posted October 1, 2004 Posted October 1, 2004 I'm PHP newbie and I would like to have news section on my site that looks something like this Where to start ? Quote
LisaJill Posted October 1, 2004 Posted October 1, 2004 Unless you want to do it manually *grins* I'd suggest having a look at "blogs" through hotscripts.com and doing ga search here. That's the most common way to deliver news. Some are easier than others to integrate into an existing design. Quote
allaboutmadonna.com Posted October 1, 2004 Author Posted October 1, 2004 There are so many on hotscripts.com ... Did you use some of them ? I'm looking for freeware Quote
LisaJill Posted October 1, 2004 Posted October 1, 2004 My entire site is managed with ExpressionEngine. Of the popular free ones there are wordpress and textpattern - but these are not that easy to integrate with an existing site, although that may have changed, I am a bit behind. There are quite a few others but you want something fairly simple. Unfortunately, sometimes going through hotscripts.com is the best thing to do. =) Quote
allaboutmadonna.com Posted October 10, 2004 Author Posted October 10, 2004 Thanks ! I found a really good one (CuteNews) on cutephp.net ... Quote
oompahloompah Posted October 11, 2004 Posted October 11, 2004 I agree with Lisa. Hotscripts is a really useful place, and yes it does take awhile to go through them but you can go by the general rule of thumb that popularity generally means that a program's not too shabby and have a look at the popularity ratings to guide your choice. Quote
