Hello,
I need to do the following every day, basically i need it to backupmy phpBB database, but then to copy the data into another (on the same website/cpanel) database, but not overwrite any existing data, just update the data. Make sense?
(E.g. say i have post 1, 2, 3, 4, 5 on the existing database, i back this up, and then transfer it to the other database which only has post 1 and 2 in, it basically doesnt overwrite this, but fills in the rest!)
Any ideas anybody?
Thanks
Jimuni
*waves to all TCH staff*
Hey Jim, how are you? ;)
I don't have much time but here's a thought:
Create a PHP script to be called by a cron job. The PHP code in it would perform the following tasks:
1 - get the last post ID from the backup database.
2 - get all posts from the main database with an SQL query using "WHERE pid>$last_post_id".
3 - insert those posts into the backup database.
I can elaborate on that later, if you want. ;)
