Hi...I can't seem to get the following error to go away. I've been working on it for about a week, and just can't seem to get it. Happens when I input a invalid email..validation works, but then I get header error.
The form was not submitted for the following reasons:
your email address is invalid. Please use your browser's back button to return This form is powered by Jack's Formmail.php 4.2!
Warning: Cannot modify header information - headers already sent by (output started at /web/xxxx/public_html/contact/scripts/webmaster.php:234) in /web/xxxx/public_html/contact/scripts/webmaster.php on line 374
and here's my code (private data edited out of course)
$redirect = "http://www.xxx/contact/after_mail.htm";
// our mighty error function..
function print_error($reason,$type = 0) {
global $version;
build_body($title, $bgcolor, $text_color, $link_color, $vlink_color, $alink_color, $style_sheet);
// for missing required data
if ($type == "missing") {
<p> </p>
<h2>The form was not submitted for the following reasons:</h2>
<ul><?php
print("$reason.\n");
?></ul>
<p>Please use your browser's back button to return to the form and try again.</p>
<?php
} else
// every other error
<h2>The form was not submitted because of the following reasons:</h2>
<?php
print("<br><br>\n");
echo "<small>This form is powered by <a href=\"http://www.lumbroso.com/scripts/\">Jack's'>http://www.lumbroso.com/scripts/\">Jack's Formmail.php $version!</a></small>\n\n";
function mail_it($content, $subject, $email, $recipient, $allowed_email_recipients_array) {
$recipient = $new_recipient;
mail($recipient, $subject, $content, "From: $email\r\nReply-To: $email\r\nX-Mailer: DT_formmail");
if ($required)
$require = $required;
// handle the required fields
if ($require) {
// seperate at the commas
$require = ereg_replace( " +", "", $require);
$required = split(",",$require);
for ($i=0;$i<count($required);$i++) {
$string = trim($required[$i]);
// check if they exsist
if((!(${$string})) || (!(${$string}))) {
// if the missing_fields_redirect option is on: redirect them
if ($missing_fields_redirect) {
header ("Location: $missing_fields_redirect");
exit;
$require;
$missing_field_list .= "<b>Missing: $required[$i]</b><br>\n";
// send error to our mighty error function
if ($missing_field_list)
print_error($missing_field_list,"missing");
$content = parse_form($HTTP_POST_VARS);
// if the env_report option is on: get eviromental variables
if ($env_report) {
$env_report = ereg_replace( " +", "", $env_report);
$env_reports = split(",",$env_report);
$content .= "\n------ eviromental variables ------\n";
for ($i=0;$i<count($env_reports);$i++) {
$string = trim($env_reports[$i]);
if ($env_reports[$i] == "REMOTE_HOST")
$content .= "REMOTE HOST: ". $REMOTE_HOST."\n";
else if ($env_reports[$i] == "REMOTE_USER")
$content .= "REMOTE USER: ". $REMOTE_USER."\n";
else if ($env_reports[$i] == "REMOTE_ADDR")
$content .= "REMOTE ADDR: ". $REMOTE_ADDR."\n";
else if ($env_reports[$i] == "HTTP_USER_AGENT")
$content .= "BROWSER: ". $HTTP_USER_AGENT."\n";
mail_it(stripslashes($content), stripslashes($subject), $email, $recipient, $allowed_email_recipients_array);
// if the redirect option is set: redirect them
if ($redirect) {
header ("Location: $redirect");
exit;
} else {
print "Thank you for your submission\n";
echo "<br><br>\n";
echo "<small>This form is powered by <a href=\"http://www.lumbroso.com/scripts/\">Jack's Formmail.php $version!</a></small>\n\n";
exit;
any help hugely appreciated thanks a bunch
jeff
Ji Jeff,
Welcome to the family :)
This is usually because when you edited webmaster.php there are some blank lines at the bottom of the file after the cloing php statement. Delete any blank spaces, and it should cure that problem
