Does anyone know how to change the time of a session?
I would like to make my time longer before it disconnects me
but I just can't seem to find that answer in CUTE FTP help.
For example, I load a file, then I might be working on coding, and I come
back and I have to reconnect to my site.
Thanks!
Weezy
The server will disconnect you after 15 minutes no matter what you set your FTP program to do if you are not actively using the connection.
I would be thrilled with 15 minutes.
Right now I get about 1 minute. LOL!
:huh:
Thanks for posting!
Weezy
OK, I use Cute FTP 5.0 and if you select Edit and then Setting and then the Connection tab you can set the timeout there. Then look at the Smart Keep Alive settings.
Edited by TCH-Bruce
